Need A Clutch Puller
Anyone in heber or park city have a clutch puller for an 07 M8 that I can borrow?
I thought I could just teflon the bolt that holds the primary with some oil and pop it off.
I am torquing it A LOT. So I figure I need an actual puller. Unless someone can tell me if I am doing something wrong.
Thanks in advance and any help is greatly appreciated.
You would need to use water not oil with that trick, water is incompressible oil is compressible that is the difference.
Not sure on a Cat but if the threads for the puller are the same as the threads for the bolt that holds the clutch on this method should work just fine.
Cool, thanks man. I had read about it being done both with oil and water, i figured i didn't want water getting into areas it wasn't suppose to be. I will give water a shot then.
