Need a anti fog remedy!
But gogles with the elimators may be my only hope. And I like the idea of having gogles with my perscription in. Has any one complained that they had problems seeing through the perscriptions, being that they look like there further away from your face than normal glasses?
When you get goggles or inserts made, the optometrist should be taking a measurement on how far they will be from your face as well as pupil distance (distance between the pupils). You should bring your goggles with you with the inserts to have them made correctly.
thanks alot guys... assasin .. I entered your code in and it said it was incorrect? on the 70% off the eliminator.
I'll look into the code. Does it say it is incorrect or no longer valid?
I'll check into it, it could be expired. I was a little surprised that it lasted that long. It is usually a weekly deal.
i've rode with glasses for 8 yrs now, main thing is to keep core temp down, take layers off as needed
scott otg with antifog applied before you leave the trailer
With soap, I think the trick is to apply it liberally, and then wait for it to dry completely before buffing it. If it turns white when you first start buffing it then you know you used enough. Just keep buffing until it turns clear. As long as I coat them with enough soap, I never have a problem with my glasses fogging.
