Mystery Parts from the Dragon's belly
While doing a top end, I found these parts laying under the motor. Any clue to where they might go. Before you say it, all four motor mounts are accounted for. On the second photo, you can see where I scraped at a metal washer attached to rubber. The inside has a different metal and the outside 1/8" is rubber.
A sloppy grease monkey at work, eh? The thing is I bought this sled with 500 miles on it from a trusted friend and said it had never been to the shop except for a Pipe/Can install.
motor mount PTO front... Search the forums for this... you will find all the info you need.
Crap, you guys were right. Upon closer inspection i found the bolt going through the PTO mount snapped all the way down at the nut. Has anyone been able to drill with a right angle drill down there and easy-out the rest of the bolt without yanking the engine. My reservation about yanking the engine is that I don't have an alignment tool.
Thanks
Ive searched old threads but can't find what I'm looking for
Wont take ya long to pull the motor. As far as alignment, I belive the engineered mounts are fixed/non-slotted. It will only go where it goes OEM unless you slot the mounts yourself. Make sure to use a good ARP replacement motor mount bolt going back in. Good luck. EW
