My review of the 08 700 Dragon
C
CoyoteGirl
PROS-
• Steering column has pivot for risers, saves you a few $$ when you need risers.
• Tunnel is nice and tall, helps when riding in trenches to not have your running boards dragging the sides and your track not touching the bottom!
• Tunnel has pretty good traction.
• Tunnel is kicked up in the back for foot placement when climbing.
• With the point above, they left the tunnel open so that when carving the snow doesn’t pile up here, it flows on through.
• Computer that allows you to see max rpms, water temps, trip odometer, current RPMs and MPH
• Light, moving her around in the garage I don’t need (although it makes life easier) the little turtles anymore.
• Reverse, it’s just fun to play with.
• 2 wheels on the inside at the back axle
• Their extrusion on the back of the tunnel for the addition of a bag or a gas rack is a slide system. No drilling holes, it took me 3 minutes to install my new bag. Very nice feature!
• Deep footwell to dig your toes into, even with HMK boots.
• Tunnel reinforcement, no saggy running boards.
• Narrow seat for gripping w/ your legs.
• Taller seat so your knees don’t bend past 90* when sitting.
• Comes with scratchers.
• Team secondary clutch for easy belt change.
• Team secondary is great for backshifting, and I have no belt heat issues.
• Feels like it crawls up on snow fast, doesn’t trench.
• The engine braking is great, when you learn how to get it to engage!
• For the small displacement, in the heavy WA snow she feels like she will tractor along as long as I care to push her.
• Stable climber, show her where you want to go and she’ll hold the line.
• She doesn’t wheelie, skis stay about a foot off the snow when climbing. When you do hit a bump and the nose comes up, quickly blip the throttle and she’ll come right down.
• The nose doesn’t want to dive down on long sidehills. (still have swaybar in)
• So far, the Aarms are stronger than a 5” diameter tree.
• Quiet.
• Ability put a pipe/can on w/o having to buy a fuel controller box.
• Compared to other EFI sled’s I’ve ridden the throttle response is pretty crisp.
Cons-
• Have to unscrew side panel to get to clutch. It is pretty simple, but I don’t like needing a tool to do that.
• If you bought it new, you would have to revalve the shocks; even the lighter riders are having to. (I bought from dealer owner, he’d already done that)
• Shocks in general… they do not have room for adjustment (preload/ rebound).
• No storage in the seat, but this is only a negative because you have to buy their tunnel bag. Which, I prefer that bag over stuffing my stuff inside the seat. So, this one is a wash for me.
• The mountain bar is on the backside (and angled toward the rider) of the handlebars, this puts it in my chest when climbing steeper hills.
• Starting, have to pull the cord all the way out to start.
• Not sure about the track on hardpack conditions.
• To use the bolts (allen heads) that come with most of the risers out there it is a struggle to get to them with an allen wrench due to the proximity of the console.
• The brakes aren’t all that great.
• The proximity of the front bumper to the front of the skis allows the bumper to dig into a hill (and not flex like the skis will) if you hit it straight on.
• A bit harder to start if you kill it after a long decent.
• Would like a little wider running board.
• Not enough snow removal on the running boards, had to install Better Boards.
• I look at the rear suspension and wonder if they REALLY DO need ALL of those parts! Lol
• Slippery seat.
• Cornering on the trails the inside ski always comes up (and I go slow on the trail!) and she still has the sway bar in.
• One of the biggest cons for the 07/08 season was the lack of production and the timeline of the production of the 800s!
Some of my thoughts:
Some of the reasons I went with the 7 instead of the 8 are:
• I hadn’t heard of ANY issues with the 7s and the 8s have had a few things. Getting clutching dialed wasn’t so easy, midrange bog.
• The 8 is a monoblock cylinder and only has room to be bored out to an 860 and the 7 can go to an 840.
• I’d have had to wait for the 8, this 7 was already in my garage. (dealer demo)
• The weight loss vs the power loss was worth it to me.
Another pro (for me ) of owning a Polaris is that I know 4 of the best Polaris gurus in the NW (Jack Struthers, Curt Bleile, Max Maxedon, Dan Jantz). When buying mine I looked at her overall potential down the road and someone to stand by their product and so the relationships come into play. Looking at any of the other manufacturers I just didn’t have that relationship w/ any of the gurus.
One thing I’m hearing is that the Dragons are quite a bit more expensive (hp for $$) than say the M1000. I’ll use that sled because it is the biggest stock displacement on the market and who doesn’t want the biggest cc they can afford eh? So, it’s hard to get past that bang for the buck (HP/$$) kind of thing. But I looked at my budget, my riding, my dealer and what I wanted to end up with for my money.
For me one of my biggest concerns was a stock tunnel; the lack of foot room, grippers, snow removal etc. I always figured if I bought a new (stock) sled I’d have to penny up for an aftermarket tunnel ($2000). Well, Poo got the ergonomics of the tunnel pretty close to RIGHT, it just needed more snow removal. Add in the Better Boards and this is taken care of. My other concern was the seat height and Poo has done a pretty good job of removing the need to go with a $500 aftermarket seat.
As for the power. She needs more, we all know that. But in her current clutched and geared state she’s going up 99% of anything I point her at. As I stated she appears to want to keep tractoring on long steep treed hills. Does she keep up w/ the SC Nytro, no, but I’ll get up there eventually! Only had her in powder once and she took quite a bit of work to get to the top of a few hills, but it was pretty fun getting there.
Adding a SLP pipe and can will allow me to lose 10 lbs and gain 6hp. Not a huge deal on the hp end, but for $500 that is the best (and least expensive) combination of power gain and weight loss you can do to a sled! Generally it costs you about $100/lb to lose weight on a sled.
The fit and finish on this is pretty good. It is a lot of what I’d want in a mountain chassis. It is a lot of what I’d want in a mountain chassis. Everyone likes their graphics, I want them gone.......
In buying a new sled, warranty is a big deal... and I honestly don't even know how long of a warranty I have! LOL I've got a good dealer, that puts my mind at ease.
The bad part of my review is that I didn’t buy this stock out of the box. So I haven’t felt the total cost of owning it ie it was clutched (I think... it runs great!) and geared which could cost a few hundred dollars. The shocks were revalved and that would cost a few $$ as well. I also didn’t have to go through the hassles of figuring out all of this. So I can’t say if it would have been worth it from that perspective. But thought I’d put together a pros and cons list for anyone who’s interested in the Dragon.
Really well done review. Appreciate your ability to give an honest list of pros and cons. Any chance you'd share your clutch/gear setup? I'd sure like to hear it.
wow, nice review. I don't think i've typed that much such i joined on here.
You have, just never in the same post, lol.
Great write up/review. Is there a turbo install review in the future? Have fun. EW
Thanks guys, I wish we'd see more of this kind of a review on sleds ie the pros and cons approach. I get so tired of hearing "MY SLED ROCKS!" w/o any explanation. Give me more. lol
Snoboy.... I'll have to look! I honestly don't have a clue. I just know she is shifting and backshifting perfectly for the treed climbing I like to do. I'll check.
EW- very very possible. Going to demo the turbo here in a few weeks and see what I think of her. Even though everyone says they've got the 2stroke turbos dialed... I need to see for myself. :D
Nice honest review, could never have done it better myself. Glad you enjoy it and its future potential.
thanks for taking the time. agree with 99%, which is pretty good, eh? re-gearing shouldn't cost you more that a hundie if you don't change the chain. i agree about the seat.....talked to the regional rep about it last night at the sneak peek. he seemed curious about the issue, there were several other guys that agreed. the 07 had a grabbier material. i noticed it when i rode the demo last year. i picked up some grabber material from a local auto upholstery store. couple yards was about 20 bucks. local lady recovered the top for me, looks better than stock and is rubberized....grippy not slippy. 30 bucks for her to do it. several local guys are going to follow suit. i have enough material to do half a dozen seats. pretty easy to reinstall cover. also thefullmonte is selling skinz protective gear covers. nice looking, supposed to be grippier material. contact him. frankly, i have not heard of a doo, cat, or poo that is setup just right from the dealer. seems like gearing and some clutching adjustments are part of the deal. unfortunately. only other comment........be REAL careful about "hooking" your feet in the toe well........i know 3 guys that have fractured (spiral) legs getting tossed with their foot in the stirrup. BAD NEWS! i always try to keep my toes angled out of the hole. food for thought.
Snoboy.... I'll have to look! I honestly don't have a clue. I just know she is shifting and backshifting perfectly for the treed climbing I like to do. I'll check. :D
Thank you CG
My new 7 is just a few days away from completion at Fastrax. It will be piped, ported, reeded, fuel controlled, and shock revalved. Fastrax is also working on a billet headset for the new 7 that I'll do before next season. BMP head cancelled.
snoboy
snoboy - you don't need to know my set up....because your sled will be DIALED when you get it back. ;) Curt is doing some fantastic work on these Dragons!!! We are in "talks" about what to do to mine this summer. I rode his 8 and it was NICE NICE NICE! :)
Bull, that is one of my biggest worries, bustin' a leg. But it feels like I need to be as far forward as possible when riding. It also helps carving to grab a toe hold, for me. But for most of the ride I'll notice that my feet are out of the footwell and pointed out. I might have to try your idea for the seat. :D
I think I have 6 rides on her... still figuring things out. :D
Great Review!!!
WOW! You did excellent! I purchased an 07 dealer demo and loved the machine. It already had the stiffer shocks and SLP pipe/can. Then my wife's son bought an 08. I rode it to break it in for him and my wife rode the 07. She got on the 08 and did not like the way it handled at all. So, after Devon show up to start riding his 08, my wife is demoted back to her 03 600 RMK. "I ride a piece of crap!!!!" was the first thing i heard. On the way home from Christmas vacation, she found me a D8! She sold her 6 and made the deal for my 8, and stole the 07 from me! So, I had to start all over. Had to get the shocks pumped up, add a 19 tooth gear, (42 comes at the end of the season) find another under seat bag, and a few other things. Now, Devon could take his stock 7 and go anyplace that my 8 would go. The 7's run awesome! I am slightly dissapointed in the 8's power. It will need a pipe/can over the summer. The taller riser on the 8 is sure nice. I did not get a chance to run both of the 7's in the hills, but in the meadows of Island Park, the 07 was always over the 08. The 07's seat was a little more "sticky" than the 08, so I am going to purchase the Skinz seat cover this summer. And I thought that the graphics sucked too. I had the dealer put a black hood off of a 600 on it so that I can get Amanda at Thin Air to design something simple and basic for the hood. Anyway, congrats an the D7 purchase! Glad to hear you like it after coming off of that big mod.
Congratulations Brandy on the New sled. Glad to see you chose the right color!
Your review was awsome and when you do this for the other brands it seems to me that the list of Pros is much higher for the IQ Chassis over the others, but once again its personal preference right...
Have fun with her... youll love it!
PS: I saw Angie in Halfway 2 weeks ago, and rode with Sarah in McCall last weekend. The snow was amazing! (2.5' fresh) We got to hang out with Jack for a BBQ on Brundage lake and demo the 09 800 and the 08 840 (WOW). Well anyway we missed ya, you would have had fun
CG
Thanks for all the great information. I just bought an 08 700 RMK three weeks ago. It was on SALE. :D This is the most fun I've ever had on a sled. The seat is slick in the powder. I have been hooking my foot in the toe well and will have to change that, don't want to break a leg. (Thanks Bull) This is just a great all around sled. :face-icon-small-coo
An update....
Found another con. :( When she is upside down, the chaincase oil leaks out. Not that cool. And getting to the filler hole? Oh man! lol
It took 15 rides on her for her to finally picked a name, Naomi. Because she is a fit throwin' b!tch when she's been upside down to long, took a good 30 pulls to get her started.
Went through my first belt, but that was due to multiple 1/4 mile long sidehills on a 70* day. Bought some vents. :)
Even with scratchers it appears that my track is getting hot enough to melt to my hyfax... I thought the hyfax was suppose to melt? :confused:
In the spring snow she is wheelie'n a bit more than I'd like, but not totally out of control. Most of the time the wheelie can be turned into a sidehill with little effort.
Checked the bushings in the primary clutch, looking brand new. This is a treat after having to change them out every 500 miles on the AC clutches! :D
Still lovin' her nimbleness. I've ridden about 50 days this winter and still have a good 6 weeks left of mushy spring riding to do. I'm pretty sure my body would not be willing to go if I was still on the Edge. I'm pretty tired as it is.
CG:
How many miles did you get out of the belt and what vents did you go with? Hell of a job on your review. Yup, it's a nice scooter.
