Don't cheap out!!! Quality fuel is absolutely essential on these motors. Consider AV gas a cheap insurance.
Lol yes it is in any turbo set up ... but I'm trying to build a turbo to run on pump gas .. is it impossible or something
Ok so here's my last 2 cents. Everyone on the internet that claims to run pump gas turbos is B Sing. 2 stroks are way different then 4 strokes. The motor stock is fine I would suggest 2 ring pistons though. My buddy had a turbo rev 8 pounds 50/50 race gas. I have another buddy turbo pro 8 pounds(lots of motor work cause they are weak stock but did not lower compression). At least start your tuning with a good gas and then dial it back from there.
I love boost just want it to work for you and not melt down. Thing can go sideways really quick.
50/50 is very different than 94. Also, lowering compression kills spool time. Basically everyone in this thread is screaming "don't run straight pump". Add me to that list. 10:1 compression, and that turbo is going to take forever to spool up.
2000 feet and under, boosted carb sled, on pump fuel.... Scary stuff for sure.
Id be on 100LL.
i get it .. i know .. race gas way safer .. easier to tune .. and makes more power .. and when i say it like that it sounds dumb to want to run 94 .. but thats what i want to do .. if i wanted to run race gas or 50/50 thats what i would be doing . and who knows in a month from now i might have a melted top end .. or worse and you can all say i told you sobut for now .. today .. im looking for info on how i can run a set up on 94 .. maybe 10:1 is to low .. some ppl say leave it as it is .. and some say no .. maybe 11.5 is where i should be aiming .. im just hoping that when it hits the dyno it is running good and making more power than it is now on 94 since where i ride that is all i can get
I noticed that you asked for advice from turbo owners. 3 people have suggested to run avgas due to your elevation and boost level but then you say that you won't be running avgas. I have to ask-if 3 people with turbos advise you to run a gas, why won't you be running avgas?
I would be the 4th to advise to use AV gas.
Drill a hole in the top of your fuel tank and thread in a 90 you can attach a hose to.
