I am a big reader of snow west (only posted once?) and now I must pass on my experience this past half season with my snow checked 2008 D8 155. Yes it arrived late, Jan 2, 2008. First ride, 40 miles. I was excited, what a different feel coming off a 2004 800 159 RMK. Now the problems/issues start. Second through fifth rides, iced up drivers. Polaris know about this problem in early Jan. Only fix was to remove the center driver. As well, the mid range bog shows up. I live in Terrace BC and we ride at 2500-5500 feet. Bog did dissappear at about 2800 feet, but what a pain in the neck. It has been there through all three reflashes. Only with a Polaris test ECU box in April did it finally dissappear. Have to get the new box next Nov. The need for a tight track is also a concern. Driver noise going down hill and the vibration. Another pain in the neck. I saved the best for last, I took the motor out at 605 miles. Both pistons (one with a burn hole just below the ring), both cylinders (therefore the mono-block) and the crank. Thank god for warranty.
Put the sled away for the season with only 750 miles on it.
Now for the good news. This is not a complaining thread, but simply info on what has happened to me. I did for a very short moment at the end of the season consider trading, but throught the money would be better spent on fixing what perhaps are first year gemlins. I love the sled and the handling, but it is down on power (at least here in the Terrace riding area, unique weather, lower altitude, high humidity and varying snow conditions). Therefore here is what changes I have made and are going to make. Any input/comments would be appreciated.
Have done the following during the season:
Gearing 39/42, Helix 64-42/44-.46, Belly Buster 64, Stock primary and secondary spring, Delrin rings, SLP air kit and vents, Fabcraft air chambers for front shocks @ 210 lbs. Pulls 8150-8250 rpm.
Summer projects:
Install Avid Extrovert drivers 2.52 pitch, change track to a 159 Camoplast series 4-2.125" 2.52 pitch (I now have both), set the rear skid back 1.25 inchs to accomodate the new track and cut the rails a little.This should free up some horsepower (5-8 hopefully) SLP or HPS can?? Not sure which one.
Thanks for any positve input.
Summer projects:
