MXC Nytro lean condition??
After a day of flawless riding I started to experience a lean condition under boost. Running 10 pounds, 50 /50 110 and premium. Seems like if I burp the gas it comes out of it. Are my mxc injectors not fireing?
check your intake tubes on your throttle bodies and or your intercooler...might be a leak allowing air in...
It just seens like it will make a couple good pulls then all of a sudden it goes way lean. So then I burp the throtle or let the boost go back to zero and it usually goes back to normal when I go back to WFO.
Make sure there is no tension on those wires at the controller. Also, make sure the boost sensing hose at the controller runs downhill, away from the controller as moisture will cause problems if it gets in there.
