What are others running for weights and pin weight/locations in their 11 or 12 Pro's for 6000' to 8000' and for higher elevations like say Cooke? Also what are you seeing for RPM.
So, what I don't understand is that I thought the MTX weights were supposed to be 4 oz heavier. Since I ride at Cooke (8-10k feet), that shows as a 10-60 weight.
That should mean that I run 10-65 MTX weights, at most, but with the spring changes that SLP recommended, they're saying to run the 10-65 MTX with 3oz in the outer hole (68 oz). That seems like it'd be way too heavy.
Thoughts? Rationale?
Running, BTW, Blue/Pink in Primary, Black/Purple in Secondary.
Thanks guys!
Thanks guys!
I am in Cooke this week trying things out. Been running the 65 gram MTX with 2 grams in the inside hole...will run 8250 to 8300 out of town on the trail, get up to 10,000' in the powder and goes to 7900 to 8000 rpm's but holds them. Late in the afternoon when it gets cooler it will pull 8100 to 8150. If I go to 1 gram in the inside hole I think my RPM's will jump to high.
Pull 1g out of the tip.
