V
You cannot have two absolute pressures in the same box. Two absolute pressures in the same box will seek their own level much like high pressure transfers to low pressure in the form of wind......you would end up with (60kpa + 101.3kpa)/2 = 80.65kpa(11.7psi) absolute or (60kpa + 70kpa)/2 = 65kpa(9.4psi). Now if your talking boost pressure + barometric pressure then you would have 60kpa(8.7psi) boost + 101.3kpa(14.7psi) baro = 161.3kpa(23.4psi) absolute or 60kpa(8.7psi) boost + 70kpa(10.2) baro = 130kpa(18.8psi) absolute.....you must add all pressures together. You are correct 161.3 kpa is different than 130 kpa and as such requires different injector duty cycle, tps input is different, rpm could be different, most importantly HORSEPOWER IS DIFFERENT. There in lies the altitude compensation. I have said too much already, your making too many assumptions about how the Polaris ECU software works. The sun still rose in the east and set in the west even before Galileo proposed that the earth rotated around the sun even though no one understood why.........for everyone else out there the Bullydog ECU tuning works awesome!
So what is the answer to my question ? How are you taking care of the altitude compensation if using the factory Tmap (re-scaled) as an input for boost pressure (absolute) ? When tweaking the facrory map in reference with the re-scaled sensor (tmap), the original map is overlaped and the changes in the x and y axis doesn t allow for compensation no more, it is now a Map Sensor.
We are using a lot of reflash solutions everyday (pro cobb, diablo, bullydog, hp tuner etc.) And we have tons of experience using reflash devices altering a lot more than just fuel, ignition, MAP, and i still don't get what' s going on....if anything is going on ......in regards to altitude compensation. I have no doubt you achieved great results with this solution compared to the piggy you were using before and i am sure you made your homework before bolding out about your kit....this being said, i am sure i am not the only one interested in a CLEAR answer on altitude compensation, not too many people on here understand how an ECU works and it is our job to inform the masses and ask picky questions.
Thanks again for your patience and hope you will light us up on this matter.
vi-pec powersports
