I can tell you that I have run flow simulation on both 2 stroke turbo, 4 stoke turbo with different plumbing to them. Side load an intercooler is less then ideal as far as pressure across it goes but it works ok and for lower boost you would never notice it.
The old M7 turbo that 1st came out they would side load an air box from the Mag side. Guess what the PTO side would alawys run lean. I decide one day to draw the manifold up and do some flow studys on it. By side loading it there wouldb 13% less flow to the PTO cylinder. An intercooler helps with this but greatly but you can still see my point.
To me the biggest concern is if you are a throttle happy type of a guy and you off and on the throttle any.
Whats going to happen with the fuel that is injected into the intake side of the intercooler?
Now you have a BOV less then 4" away from the 4th injector. What do you think will happen when that BOV opens when you chop the throttle? What do you think will happen to the extra fuel in the intercooler?
Now for the scary part!!! Your climping a hill a WOT and flip this bad boy over. Shut your motor off get the sled right side up and have to hold the throttle wide open to get her to start again. Anyone ever done this????
Now in the case of a back fire you have a intercooler with fuel in it. Can you say BOMB.
I'm by no means saying this wont work, it just not the right way todo it and the cons out way the pro's
Mike
Mike I think you bring up some valid points. All stuff we thought of during the testing and design process. This extra injector isn't supplying a lot of fuel just enough to help out were the factory ones can't. This injector only comes on a higher boost, 10-11 PSI. If this was our main way of supplying fuel I could understand these concerns. The BOV is vacuum operated so during the time you let off the throttle to the time the BOV opens that extra fuel has been consumed. In 13 years I've never needed to hold the throttle wide open on a four stroke Yamaha to start it after being upside down? Maybe I'm just lucky??
