mpi phazer info
Thanks Heath your were right once I unhooked the gems box the TPS counts went to where they should be so that is good. Now if you can tell me how to eliminate the MAP codes. I believe it is due to sucking water and causing ice to from in the MAP sensor, so I have moved the air filter but it is still under the side panel above the battery. I was thinking I should put it outside
Heath I am getting code #14 and 26 Which says the hose is off or plugged but it has not came off. I am thinking it is from water coming through the intake due to the fact that it only happens when i get in powder. But then the last ride when I would try to lean out the #2 box it would give me the codes so I had to kep it turned up and it was always to rich.
Thanks for the help guys I am now the proud new owner of a supercharged phazer, I don't have any complaints yet but I'll keep you posted. Scott
