Does anyone have setup instructions for the MPI 180 Turbo kit for the GEMS controller. My sled was snow checked and didn't include any instructions for the fuel controller. I think Yamaha doesn't want us tuning from MPI'S base points. More than anything i just need a list and or order of the functions on the fuel controler.
I have 150 miles on the kit and installed a A/F guage and was running lean at WOT. Matt at MPI suggested adjusting the red mode up 1 or 2 so i did, it seems the help.
I still have a little burble in the mid range when i hammer the throttle, it doesn't seem like turbo lag. My experience with turbo lag would be off of the low end and then hammering it and it would be kinda boggy then pick up and go, but i could be wrong. The burble seems more like a fueling problem rather than lag. The burble acts more like a stuter once or twice and then picks up and goes. It only seems to do it when cruzing mid throttle and then punching it.
I was also wondering if it could be the accellerator pump or a timming issue. Is their anybody else experiencing this??
I'm still trying to get my clutching dialed in. I have the 8FS weights loaded which i know i'm still alittle heavy running at 7000ft but i still can't get it to pull on the top end like it should. All my other clutching is at MPI's reccomendations. 15.6 rollers, 39 degree helix, pink pink secondary, green white green primary. Does anybody else have any suggestions? Also forgot to mention my boost is around 6 to 6.5#
