Moving rmk front arm in assault hole
I hope this is not going to start an issue lol. I'm sure MH is posting so all will be cautious and not jump on something without thinking out the whole scenario. Hence the big bold WARNING.
My 2 cents. Not to lead anybody in any direction but for discussion.
I've seen the pics too and looked at my sled and cycled the suspension like I've done to most my sleds.
First, comparing Cat or Doo to the Pro is apples to oranges and that IMO is a big reason this sled performs better than the rest at getting up on the snow and getting unstuck. They use involute drivers to allow the rails tips to be almost at the center of the driveshaft. They also mounted the skid to allow an initial tight track.
The other two still have to run a loose track and have many inches of gap from where the track leaves the drivers to where the rail tips begins . This leaves room for the track to balloon out AND fold back in. Kills attack angle and leaves room for stabbing. Moving the suspension back (or rail tips) is worse than moving it down for these situations.
An example from my experience. On my '12 PC I dropped the front of the rail by moving the lower shock mount forward and lengthening the limiter strap. I cycled it to get to max for the shock and still not let the tip of the rail (antique design) get below the straight line from driver to flat on the rails. Did this to make the sled more lively with just throttle input and to take away some of the front heaviness-diving during off throttle. No issues for over 2000 miles.
Cat moved back and down in '13 to get some of the same results I think BUT some of '13,s ended up stabbing and maybe trenching more lol. Loose track, room to fold in equals oops.
MH is right about the rail pressure there on a Poo skid. Saw that when I torn it down. The Poo wears the sliders on that curve unlike the rest that wear them more as the track gets on to the flat part. So I was leary of using the longer strap in the Timbersled kit and originally installed it in the 2nd hole.
When I installed the skid, I saw some room and and went to the recommended hole (full out). Bottomed out the rear sissor and it still looked OK so that`s the way it has stayed for this year. Like I said so far so good.
Front ride height is part of dialin` in a sled for sure but it is a 3 point balance at least. The Assault wide front end will sit higher. Is it more than the 1/2" hole in the tunnel?
I don't know. MH do you know if the Assault uses the lower hole and a longer limiter strap?
Any how if MH is getting lot's of PM's against trying this then I suggest you listen and think. Just like any modification from stock measure twice and cut once 'cause you are your own warranty station.
Done. Took it around yard and it feels a little lighter in the front but not crazy light. I think I'm going to like it..
Sent from my SCH-I545 using Tapatalk
I have around 500 miles with the skid in the assault location. Mostly flatland ditch banging, some mountains. No visible wear on the horns, everything looks good so far.
I will not be going back, this sled is way more fun now.
Do you have a antistatic kit?
I dont think he does. Earlier posts state he will let us know about track stabbing.
You just installed kit with tips on.
I guess only necessary to trim back if adding extroverts.
Im gonna put a anti stab on like you and drill out hole.
I put it in the stock limiter strap cross hole location. After looking at it and reading the instructions through I think I'm going to try to move it forward. Seems safer to me to move it up. I would love to figure a way to do and keep the stock tips.
Ok. Stock limiter strap location with stock tips I was not confident it would not stab. So then I moved the anti-srab kit to the front tip location. Well then the wheels could come in contact with stock drivers. So back to the front limiter strap location and cut the tips 1/2 inch from hole like instructions said. Now no way of stabing. There just was no information out there of rmks done with stock drivers.
What did you cut rails with? The give dimensions on how to chamfer the slide and or rail?
Ok, I rode and boondocked all weekend with this set-up. This is how I sum it up.
The good:
Weight tranfer is better. You can pop the front end up over obstacles much easier. Deep enough snow you can catwalk it easier.
More fun boondocking in most cases.
The Bad.
I felt vibration
I heard more track noise
handling on a trail or hard pack, the sled feels much more tippy.
In the end I will more than likely move the suspension back up to its the original factory location. I think for the difference it made in weight transfer it isn't worth the poor tippy trail manners, vibration or noise.
I didn't noticed if it got up on snow any worse than the other setting. I could pretty much go anyway with the spring snow. We had some deep spot and I even got stuck once but any sled would have in that spot.
One thing that is ofen not covered is that that with the lower hole for the suspension... the Assaults also sit a bit higher in the front due to the longer a-arms.... As a system.
Go-Big... thanks for the follow ups and the great photos.
The good:
The Bad.
I felt vibration
What dis you run your track tension? I could see running extroverts and looser track would be better.
If i bend my rails i would probably order straight 163 rails, tipped up fronts like the assault and the bomber style too.
The tippyness i dont think would bother me.
Ya. good follow -up GB. Just to finish it,,,
The track tension question is good. You must have readjusted to book spec after moving the arm. Correct?
The vibration and noise thing. I've never been a fan of anti stab (or tiny wheels anywhere) because of this. If I went extroverts it would be with the proper rails.
Hope you come back with more on this after moving back.
Did you try a couple of suspension adjustments while out to address the tippyness? Taller and narrow has a compromise on the trail for sure. Some of that can be hidden a bit with some tweeks.
But,,, in the end if the difference was not enough for you,,, it wasn't worth it. You didn't stab though lol.
Yes, I tensioned the track pretty close to factory specs. I use more of a eyeball and feel method. I have a lot of experience with tensioning tracks over the years.
I didn't mess with the suspension settings to much. Perhaps I could have dialed some of the tippyness out but we were mostly off trail so didn't worry about it too much. I have the front track shock tightened pretty good and still able to bottom it out when running the hard pack back over some moguls so didn't really feel for my weight I needed to loosen it. I'm 6'2" and around 200lbs with out all my gear on. Those shocks were serviced at the beginning of the season and seem to be working well yet.
I have at least another ride or two to go that I will be leaving it in the lower hole for and figured before the start of next season I will put back to stock. I contribute some of the vibration and track noise to the severe angle from drivers down to the rails. I figured dropping the down a hole would change the handling characteristics a bit. But wasn't expecting the trail manners to be affected as much as they were. Off trail it seem to roll easier as well which is kind of nice. I will check it out over the rest of the spring and keep updating.
I figured you had done it right GB. It was a good question because anytime you use different mounting holes for your skid it will change track tension and should be noted.
My comments on the vibration and noise thing is from my experiences with little wheels when we did a lot more of the drop and roll things in the past as tracks got taller. Now the 3" is starting it again for some.
I will say too, with stock rails I have no increase with that at the same angle.
I know why you ramped up the FTS preload on the stock skid. That spring IMO is the most important to be "personalised" on today's sleds.
It's best for climbing up on the powder to be set with minimum preload FTS. High preload with a soft spring can be tippy on the trail too but if your bottoming what do you do?
I'm about 245lbs dressed so the stock spring was worse for me lol. I used the rear spring preload to help when the snow allowed. So more planted was the result (and why I went TS rear this season) but still darn good for stock IMO.
My "personal" spring is one I've used since I "found" it 10 yrs ago lol. It's an old Holz dual spring set-up that starts a 100 lbs when both springs are free and crosses over at .75" of shock travel (the main "personal" part) to a 250lb main spring (personal TOO but not as much as the cross over point). It has seemed to work well with most standard FTS's valving too because usually that one is heavily dampened on the rebound side and light on the compression side for me. Probably why I don't use the coupling part on my TS skid very much too.
Any how something else you might want to try to make an "all rounder" sled.
It doesn't matter which hole you are mounted in
I will have to consider that especially for my next sled cause then I will have 3 full years to enjoy it.
