Moving Drivers on Sled
I noticed that my drivers should both move a little less than a quarter inch to dead center the track in the tunnel. Is there a way to do it with the jack shaft in thats not too hard on bearings or chain case of my nytro. Or do I just have to pull it.
Thanks.
I'm sure you meant drive shaft and not jack shaft and yes there is a way to do this very accurately without any damage to or loading of the axle bearings etc.
I am not sure who made the tool but I borrowed one from a fellow one time to perfectly center my drivers.
What type of axle is in your sled? If it is the hexagonal solid shaft this tool can be easily made and used.
It consists of two metal bars that are clamped onto the axle beside the driver that you want to move. Two bolts are then ran through threaded holes in the bars which push on a collar that you install against the side of the driver. The farther in you turn the bolts the farther they push over the collar/driver.
