C
What does it need to be? Installed or removed length? I will measure them tomorrow.
Lets stick with Nytros here. Different platforms may well react differently, just like cars. With the testing I did I found that 22-24+ degrees worked very well for the Nytro chassis Less than that, and the difference was quite obvious. It was very apparent when riding in deep snow. The stock Nytro caster setting is 23 degrees. What are your caster settings presently? I am assuming you have a Nytro. Depending on your A arms and subframe you may or may not have that. The prototypes I used last year allowed for independent caster and camber adjustments that could be changed quickly while I was up riding. That allowed me to assess different setups in the same snow conditions. I live VERY close to the snow so I was able to ride in all possible conditions over the course of last season.
I hope your bent tie rod sleeves work out better than the skinz ones. I bent one pretty darn easy. Seems like there should be a gusset there at the bend.
Sent from my iPhone using Tapatalk - now Free
The bend is required for clearance in the steering bellows area. If the tie rods were left straight there is a slight clearance issue in the rubber bellows area. Where you put the bend is critical. Skinz puts their bend towards the center of the tie rod, which is the least desirable place.
Looking forward to installing my Mountaintech a arms and then enough snow to rideAutopro
