If the machines are only 4hp away from each other then why do lots of guys say the summit is so much more powerful. I doubt 95% of guys can even feel a 4hp difference.
I'd say more like 100%, had an 11 pro then a 12 etec now a 15 pro, with a better power to weight ratio I'd say the advantage for power goes to the pro. The etec motor in my opinion is the best on the market, direct injection is a generation ahead of poo and cat. Weight in the trees is king and poo is a generation or 2 ahead in that department. With the 16 poo's rumored to be sub 400 with the ho motor cat and doo are going to have to make some HUGE advances.
Sub 400, Wow. Guys are having a hard time doing that with carbon fiber and titanum. and with a huge price tag.
Ill fall over if they go sub 400 lbs, we are breaking enough stuff with the weight they are now.
Well you better get some padding ready because it will happen with a 155 next year when the RMK moves to the AXYS chassis. They cut 38 pounds from the Pro-Ride chassis Rush to the AXYS chassis Rush. I was told by a Polaris engineer at the West Yellowstone Expo this year that approximately 15 pounds of that was just in the rear suspension. That gives them an easy 20 pounds on the rest of the chassis.
So the 155" PRO is already at 417 dry ....... 399 or less is just around the bend!!!![]()
yamaha 300hp.
