I see. I ended up with the TKI 36" upper arms and ARS II spindles with that possible outcome you mentioned in mind. Was just curious to know what i would have ended up with in the Mtn.side option. I also changed from stock skis to Mohawks so im not quite sure which part who did what, but i will test that later. Either way, the result was lighter effort and less understeered compared to stock. I might also change the stock FTS spring to some longer or stiffer option since i already have tightened the stock one more than reasonable. I have not tried the current setup out in the deep and steep yet and i am not that experienced offtrail rider either to give any info of worth. Thanks!
