Hey TMK
You would have to call Van Amburg Enterprises to find out current pricing but off their web page +/-$450.
http://vanamburgenterprises.com/catalog/index.php?cPath=31&osCsid=89ae0541fbd0da6b6c53bef9a4f9ca13
Hey Pelon
Thank you for the information. Are you saying that it is 7 lbs. heavier then the short stock tunnel cooler? Also are you planning on deleting the stock radiator or have you already done that as well. It sounds like that is an additional pound or two off the front.
7 lbs isnt a big deal becuase it is down low plus it sounds like it will keep the tunnel cleaner from ice build up so that is also a plus. Please let us know if you run into any issues with the install.
I talked to MPI today about getting my ecu flashed to run on pump gas and asked him if the MPI unit would work with the rear turbos. He said the one I have will not, but that they have a replacement for the type I have that will work with all turbos and gives the same cooling performance. The one I have is being discontinued since they do not want to build several types when one will work. So get ahold of them and get the details so you can compare it to the others on fit, finish and price.
