The OEM Nytro cooling system is often inadequate for the higher cooling demands of high horsepower supercharged and turbo charged snowmobiles. Drawing from our 12 years of Yamaha Tunnel and Cooling experience base, we designed the tunnel coolers to work with even the largest tracks without modification to the tunnels appearance.
This kit can be used with or without the OEM radiator. This makes it possible to shed even more weight from the snowmobile while still enhancing the overall cooling system. This is no little cooler. The actual extrusion measures just over 8 feet long. YES! E I G H T FEET. Compare this to the OE tunnel cooler that isn't even 2 feet long!!
Performance improvements are HUGE! Typically 60 degrees cooler with our tunnel cooler and the OE Radiator. Typically 40 degrees cooler with our cooler only (that's you eliminating the OE radiator and OE tunnel cooler).
Get them now on our SUMMER BUILD SPECIALS!!! 464.95 retail ...On sale now for 400.00!!!!
