Wanting a lighter weight oil. Would MOtul Snow Power 4T 0W-40 work [2014 yz450f]? Technically I believe that oil is for snowmobiles (4 stroke)
Is the oil you are using bike specific oil or is it car oil or snowmobile oil? And does the type of oil matter given the use of a bike in the snow?kayaker, fwiw, I am not familiar with motul. I have had great luck with Mobil 1 European formula 0w40. Not ma wet clutch tested so initially I was concerned about clutch slip. I also never slip my clutch when riding. About 1000 hrs on three different bikes. I've had all three engines apart and found virtually no internal engine wear. I've also had the clutches apart on all three, all were in great shape, I replaced nothing. Two of those bikes, fx and exc, both had 400+ hrs on the original clutch when sold. Both still going strong. I recently had my current bike on the Dyno. No clutch slip noticed at max torque and hp. Original clutch (200+hrs) always 0w40 mobile 1. You have to start with a good functioning clutch. Glazed discs would be more likely to slip. If you like to read about oil testing this oil tested well by engineer on site, oil test rat 540
Yes of course. Motul is quality oil but spendy. Didnt know they labeled one as “snow bike” oil but I highly doubt its any different than their other 4 stroke race oil. Last year i ran a motul 0-20 because i was getting it for free and it worked awesome. I changed it every few rides and it always came out looking good still. I also ran the mobile 1 “european car formula for a couple seasons and it was fine as well and much cheaper. It would usually look pretty smoked after a few hard rides but didn’t matter because i rarely went over 3 rides with it and often less. I am going to change it less often this year running the motul unless i run my bike super cold for way too long or it runs upside down for an extended period while i am fighting to get back to it to shut it down.Wanting a lighter weight oil. Would MOtul Snow Power 4T 0W-40 work [2014 yz450f]? Technically I believe that oil is for snowmobiles (4 stroke)
I'm looking to switch oil up. Debating on the European Mobil 1 0W40. Have been running Rotella T6 5W40, but looking to try a 0W rather than 5W to see if that helps the cold morning starts. I have a Rekluse, just curious if any of your bikes ran that clutch without issues on this oil?kayaker, fwiw, I am not familiar with motul. I have had great luck with Mobil 1 European formula 0w40. Not ma wet clutch tested so initially I was concerned about clutch slip. I also never slip my clutch when riding. About 1000 hrs on three different bikes. I've had all three engines apart and found virtually no internal engine wear. I've also had the clutches apart on all three, all were in great shape, I replaced nothing. Two of those bikes, fx and exc, both had 400+ hrs on the original clutch when sold. Both still going strong. I recently had my current bike on the Dyno. No clutch slip noticed at max torque and hp. Original clutch (200+hrs) always 0w40 mobile 1. You have to start with a good functioning clutch. Glazed discs would be more likely to slip. If you like to read about oil testing this oil tested well by engineer on site, oil test rat 540
