Motor Swap
SixtySevenGT
Going to put an 06 motor in the 05, I believe if I change the Cylinders on the 06 and just use the Bottom end with 05 cylinders this will work.
Anyone ?
I need a set of of stock 05 cylinders, anyone got a usable set.
Then I can use the 06 cylinders in another sled with a better crank .
Ya Id say that will work. Only difference I see is injector holes on the 06 cylinders. I rebuilt my 06 and a friends 05 and that's the only thing different I recall.
Mark
Moving Foward
OK-
So I got a set of Cylinders to put on the 06 bottom so I can put it in the 05 Chassis.
I will post pics as I go --
Needed for swap - 05 ECU
Any body got a 05 ECU for sale.
Preferred a SLP flashed ECU for 05 900 with the SLP Pipe Head Can
Starting this week
So I got the little Womans 685 rebuilt now its time to tear down the 2 nines.
I may be needing a set of 05 engine cases --
Anybody or did or is the last used set in the world gone ??
