If you have a 900 or 2006 700 (755) IQ... there is a good chance your motor mounts are broken (Torn).
There are a lot of reasons this happens....from the overall torque of the motor, to the position of the secondary clutch on the 2005's to super steep helixes, to poor construction to people
prying up on the motor to get access to parts.
Most of the 2005's that I've had apart have torn motor mounts... many of the 2006 I've done have the same thing.
Belt life, crankshaft failure poor performance and inconsistent running are all symptoms of these mounts going bad.... but some might not really notice with these new 3211115 belts on the sled...
but the performance will be down and this exposes your crankshaft taper to abuse and possible failure.
The fronts more than the rears... BUT if your fronts are ruined, the rears were probably damaged as they try to hold the motor in place by themselves.
The bummer is you cant tell if they are torn until you pull the motor.
It is good preventative maintenance to replace these as they are inexpensive from www.hiperf.com.. they only list the 2006's but they fit the 2005's as well.
#345-512 fronts, #345-513 rears
Listed for 2006 only, but they also fit the 2005's
Get your fuel filters for the 900/755'shere too.... cheaper than the dealer.
If you remove your stock mounts, to see the damage, put it in a vise as shown.
This pic shows a 2005 900 front motor mount. The mount was "laid over" in a vise to show the torn rubber.
This mount looked normal at first inspection!!
IMO, best to pull the complete engine and give yourself the ability to clean and check everything out.
I also strongly suggest replacing all the bolts in the mounts with Grade 8 or better (L-9 or ARP high strength bolts)
(4ea of #18, 2ea #9, 2ea, #16 fro the diagram below.
Now, if you want to go with the ultimate front mount that is basically a bolt in (you will only need to drill 4 holes)... go with Compfusion's mounts (compfusion is a members name on this forum)
super high quality stainless steel, urethane and aluminum components.
