Motor Break In?
5.00 star(s)
I also will be putting my engine back together today. What else should i do while putting the pistons in
Why are you putting your motor back together? What have you done since wednesday? Oh, and to answer your question, oil EVERYTHING!!
Got bored so i put in a new set of pistons :) I also need something so i can change my primary clutch weights.
I would make sure you have cylinders honed if you don't and use assembly lube on your wrist pins,make sure you measure everything that needs to be during assembly, clean cylinder walls good after honing,coat with oil, put er back together and mix 100:1 for a tank or two. You should buy a service manual and follow steps it explains clearly if you don't know.
oil is alright for assembly but if you want to make sure that EVERYTHING STAYS COATED use lubriplate engine assembly grease. it'll smoke for a little bit though but if your engine sits a couple days or longer with out being fired off you'll have no worries.
