Moisture inside trailer
Knox
Ran my furnace in my trails wrest trailer for quite sometime the past well and noticed quite a bit of moisture on the walls and roof and was wondering if there was a cite for this or anything opinions
Sent from my DROID RAZR using Tapatalk
Also, that's assuming you have a forced air vented outside furnace and not a radiant heat type of furnace. They throw out the heat. But they also fill the trailer with moisture. Beyond that, crack a roof vent to let the hot moisture escape.
Agreed
Propane makes water so you gotta vent it. Or have a forced air vented to the outside so the vapor from propane is sent outside
How cold was it outside? Our fish house get condensation on the walls when it gets really cold outside.
Anybody know how long the two bottles of propane last on the trails west. It seems it's a lot harder to get the temperature up in the trailer when it's full of sleds. I'm noticing the same moisture on the inside of the trailer as well
Sent from my HTC6500LVW using Tapatalk
They have lasted me quite awhile this year with all the working inside I have done with it already, I have noticed that it takes quite sometime to fully heat the trailer as to wear it hardly ever gets up to temp and kicks my furnace off, I was almost thinking of running a dual heater setup what do you guys think
