mm700 156 camo track tearing need advice
So here is the gig
2000 mm 700 with a 156 camo, bender pipes, blah blah blah,,,,,and EXTROVERTS
I tore a 156x15x2.52 camo three seasons ago, speared a rail ( the rail end cap was gone) I blamed it on myself for running the track too loose.
On Friday I was at Togwotee and came to a hill on the first day, I have started running my track tighter since I figured I tore the first one that way. Well, I didnt hit anything, the hill I was climbing went from flat to a 40 degree angle, I hit the hill and powered on the throttle, that track tore and double wrapped around my driveshaft, bent the driveshaft, etc. Had to cut it out and tow the sled back.
So, I run the track loose, I tear one, run it tighter, I tear one, what do I do? Is it my extroverts, are they picking up the track? The rails are not bent, it looks like it may have speared, but it tore straight accross, no torn lugs in that area?
So now i am tearing this sled down, I have decided to keep it ( I rented a m1000, rode an m8 and dragon 800, not at all impressed, I will run what I have for a while longer) what should I do? I am thinking about a 16 wide track, I like the camo 156x15 2.52p Part number ends in 9808, seems to be an awsome powder track. Do I go to stock drivers? Big wheel kit in back and anti stabs in the front?
What do you reccomend?
Thanks for the help
Powpow
(Jeff Ryan)
