Did a search and have not found much. A friend has a 2001 mm700 and put a set of slp triples on it. We ride mainly 7000 to 10000 feet. what would you recomend for clutching and jetting? Thanks
jetting 132.5 mains straight across needle in 3rd clip one washer over and one under to start pilots 60 and 1 1/2 turns out on the fuel screw should get you dang close to start but I have slept in the last few years. Clutching stock a 46/42 helix worked pretty good and the ch(?) weights worked a little better than the stock cr's secondary spring green wound at 70 to start get it turning around 8700
