Mike Taylor Footwell Vents!!!
These vents aren't the easiest thing to install, they do fit tight, just takes some bending and flexing to fit them in place. I havn't personally seen a '14 but I think they are the same as my '13.
They look good. What paint did you use for the white? I have been thinking of doing that but want to find the best paint possible so it doesn't look like **** or flake off.
They Come in Black Plastic, White plastic, the rest are painted with krylon plastic paint. WE can match wraps or wild colors.
Thanks Mike
Has anyone tried these on a 14' ? Mine just came in and something doesnt seem right...probably have a lot of trimming to do methinks
I just put a set on my 14 no trimming required. Pull the torx screw out of the belly pan on the side and slip them in under the hoop - drill and rivit, done!
Cheers
whats the advantages of the vents
They are designed to keep snow out. When you ride you tend to kick snow into the stirrups and then into the clutches or drive belts on the newer Pros. These will eliminate that issue but still allow heat to disperse through the screens.
And keep ice from sticking to the bare alumn. And finish off the tunnel.
allows better footing.
Thanks mike
