melted piston on HCR: Why?
To Mbcat: I am running the oiler and the extra oil in the tank so I am richer in oil than others.
I changed the gas pump because the original one was delivering less then 35 PSI
The BDX Extreme fuel pressure regulator pump is preset to 40 PSI but I can raise it: so I was not turning my pressure down but bealiving in factory settings.
I had years ago a foulded injector limiting 1 cylinder . After cleaning worked fine. So I added a fine particule gas filter in line (after the pump) to avoid to renew that experience.
Will the filter take few PSI away????
Not to be sarcastic but you've succeeded in turning a reliable Suzuki into Bomb/popo! Put all your fuel system back to stock and quit with the oil in the tank
