Hello,
Please give a look to these pictures.
I changed end April 2014 the 2 cylinders and 2 pistons of my HCR 800 after I had punched a hole in the heat exchanger, lost the coolant and overheated hard ....My fault….
Now, after 600miles I melted 1 piston. I did a good break in procedure.
Since few years I run always extra oil in the gas grade 90 (say 1/100) to balance the very poor oiling when throttle is in low settings.
My injected oil amount is correct related to daily miles.
The engine died after a short steep climb fallowed by the descent and almost idling to stop near my friend.
Water temperature was around 100°F (have a digital gage now…)
No warning on the dash (egt temp or knock sensor)
Checked the spark plugs at that time : light brown color but not to much (no pictures because I came back over oiling so they are black now)
I poured oil in the cylinder and plenty oil in the gas and did 10miles home 5000rpm mostly down.
What’s wrong????
78A Top bad piston
Almost no “wash” : that will be meaning running lean. But EFI is on that side
See bottom of that link
http://www.trackshare.com/forum/showthread.php?t=75715
79B bad piston exhaust side
Why the bad piston melted where the little oiling holes are?
80C bad piston intake side
81D bad piston from below
The black spot tells how hot the piston was running usually: cooking the oil
Here small spot , I believe.
85H bad cylinder right from exhaust
86I bad cylinder left from exhaust
87J bad cylinder intake side
Piston melted where they are no port holes…. Strange!
96S bad cylinder after cleaning intake side
I cleaned out the alu deposit on the cylinder and honed it but they are deeps remaining. I was thinking that the hard layer will peel but is appear as eroded or hammered...
88K good piston exhaust side
The “blow by” is changing all arround
89L good piston intake side
93P good piston from below
90M good cylinder right of exhaust
91N good cylinder intake side
92O good cylinder exhaust
Why the scratches on the good cylinder has hight as the top ring?
Easy to repair the top end of the engine but I will be happy to know why it broke down.
I am not always such close from the road to go home!!!!
Please give your comment
Thank you
Michel
What’s wrong????
78A Top bad piston
Thank you
Michel
