This is a used set of Polaris TURBO weights along with a black/green primary spring from Steve at MDS clutching. If you haven't tried this you don't know what you are missing. Currently set up for high altitude 800 Polaris PRO with a Boondocker Turbo. Comes with all the shims, bolts and washers to dial it in for your riding needs. Steve is a great guy to work with and will always return calls even late a t night to help you adjust these accordingly. Give em a try you won't be disappointed.
$150
From Website:
http://mdsclutching.com/Home_Page.html
P1-T’s--POLARIS TURBO
Countless hours of design & development went into our weight designs. Using only OEM springs and helixes in our testing we were able to achieve more HP to the track (8 HP Avg), cooler belt temps(added belt life) and lower clutch temps (less slippage) which all add up to one thing BETTER PERFORMANCE.
$150
From Website:
