B
boostedballz
I have a 2006 Apex with a stage 2 MCX Kit. Put over 2000 miles on the machine last year without any problems to speak of. First ride out this year it would barely start in the trailer cold. After some convincing and noticing my A/F gauge was reading well into the 14's finally got warmed up and we headed out. Sled seemed to run normal as it should since nothing was changed over the summer. Once I got up to altitude I noticed my boost was down a bit as well as my RPM. I usually have to go a couple of clicks on my boost controller once i'm at altitude to dial in. I continued to play and the higher I got the worse my boost and RPM got regardless of how much I turned my controller. After the weekend of riding I dropped the machine off at my yami dealer thinking I had some sort of intake or exhaust leak. After several hours of going over the entire system he found nothing wrong. I took the machine out again and found it building anywhere from 10-12 lbs and a slow to build. It was about -7 celsius and fairly hard packed conditions. Last weekend it would pull 11-12 in a packed trench but fall on its face in the fresh. The kicker is it runs perfectly as soon as I descend to the truck. After cranking the controller up at altitude it builds as much as 18 lbs on the trail on the way down. I have tried every thing I can think of and talked to several dealers without any change. Any ideas would be hugely appriciated.
LL
LL
