Mcx stock compression 240 kit info?
seano700
Last spring there was talk of an mcx 240 kit with stock compression. Anyone have some details on it? Fuel requirements, base kit, timing control.
Thanks in advance
Sean
Think only the 180 kit can run on stock compression. If you run 240 you will need good fuel on stock compression.
The Evo kit at 275 with stock compression requires 100 octane. I had seen something on the mcx 240 kit in the spring but don't remember the fuel requirement.
Thanks in advance
Sean
Yes u can get stock compression 240 MCX with Viper.. Contact Leiphmer Yamaha... Talk to Mark and he will set u up!
Thanks fellas.
Hopefully our mcx distributors can chime in.
Should be a good year with lots of new technology from boost-it, evo, and some of the others. Hopefully mcx has something to offer too
