So here is the hole story, went to cooke rode all day, loaded it on the trailer went home. Next weekend started it up was letting it warm up and it was smoking abunch for about 5 minutes then it went away. So I pulled it in the garage, went out a couple of days later to do some work on it and I noticed a film of oil all over the suspension and track. I have a CR tunnel dump on it, so I got to looking and there was oil in the tailpipe piece. So I went ahead and pulled the seat off started looking for leaking lines because I thought they maybe it was one of them, there was oil from one end of the track to the other. But then I got too thinking that's because it was coming out of the tailpipe above the track. The hole reason I started this was to pull the header off because it was cracked, then found all this, so in my thinking I thougt look in the header for oil and at the motor end there was none but were it bolts to the turbo there is a little oil. That's when I called Mark and he said to check the suction pump, and it's not that so I need more ideas and help!!!
