Last trip out mid day I lost the ability to build boost. I went through all the basics, I was assuming the charge tube just came off but it did not. BOV was working find, wastegate looks good, no vacuum leaks, no exhaust leaks, main connector was plugged in, Intercooler was fully on.
What I end up finding was the 2 wire that runs to the altitude adjusting piece had rubbed through, tapped it up and bingo building boost again. Later on it was loosing again but I think moisture was working its way in to the "short"
because the boost would come and go.
Later that night I spliced in a new piece of wire and the next day appeared to not be loosing boost. Conditions on last day were crappy so did not really get a great chance to test it.
Does this make sense? Short in that wire causes default to not able to build boost?
8000km, the sensor system has worked perfect and felt no need to change it. I know a lot of people swap them out for a manual controller but mine has worked great.
Thoughts?
Thoughts?
