Because MCX have a completely separate system for fuel the MCX display only adjusts those injectors, while RB3 adjusts stock injectors, they are two separate systems, and thats why i have both, i want to be able to adjust settings both off boost and on boost, maybe overkill, but w.t.h. we live only once.
Yupp, thats exactly what you can do, you get perfect control of everything going on, i also often use logging when i adjust the clutches for example, you have absolutely track off what rpm you have on certain boost levels.
If you already have lambda and boost instruments and can live without being able to adjust the electronic boost controller and logging you might be better off with an RB3 or Dynojet PowerCommander 3 (two systems similar with each other) i know i wouldn't bought the MCX display if i already had those, but you asked for the best bang for buck, and you get alot with the MCX display, but the RB3 or PC3 are very good 2, only diffrent.
