Another new guy to the Tnytro. 08 Nytro w/ 240 MCX kit, 162, Shock Wave, on premuim, believe stock gearing 20-40.
Had it out for the first time in the hills yesterday, it pulled great down low at 2600 ft running ~ 8900 RPM when opened up and ~ 13-14 psi boost 9not sure of track speed, never thought to look, plus it was a blur!
Once we got up a bit to 4500 ft, noticed the sled didn't run as crisp, not really bad but just noticable. Would pull 14 psi but only would get 8300 RPM out of it (still hauls!) but not as "clean" feeling (suspect icing on this). Seemed like it had to work a bit harder to get up and going.
My question is if its normal to only go 2000 ft and see this type of change, I would assume not. I did have my air filter icing up a bit, would clean in and it would run cleaner, but still could't pull RPM's like below. Once we got back down it ran great again. just seems funny with only 2000 ft elev difference.
I know I need to find out clutching more detailed, and will do that tonight hopefully, if it is this? Only other thing I was thinking would a small leak in the exhaust pipe or boost pipe do this even though I was still pulling boost - seen this happen on an APEX but it was more noticable.
From what I know so far is: primary has a Back/Purple mark Spring?? 14.5mm rollers, not sure what weights. Secondary has the Shock wave and looks turned in quite a way - would guess 1 or 2 out (will check), and Black with a white mark spring.
If its clutching, I can work on this, just wondering what direction of trouble shooting I should head.
Thanks
Thanks
