MC-XPRESS Ski-Doo 1200R 436 Hp
A
APEXXPRESS
Hi Mark
We tested yesterday a SkiDoo 1200 with 436 hp.
Bigger turbo, Wahlbro fuel pump and injectors + race gas and 200 kPa turbo pressure.
Race cams , racing valve springs, stock pistons, rods, crank and head bolts.
We placed the intercooler in a water tank to get efficient cooling.
During one run a hose blow off.
Alf had to change his underware after that.
Best regards Erik Marklund
http://www.youtube.com/watch?v=Ho-WTc77rtA
Turbo
Turbocharger MCX550
Twinflow turbine housing for rapid boost. Separate wastegate and blow off valve required. Suitable between 350 - 500 hp. Max 550 hp.
This run was at 29 PSI Boost
Kit is a one of at this time. Depending on demand there may be a very limited run of these available this spring. Outside of a race only sled I would not reccomend this kit for daily use as the turbo is extremly large and not very reponsive. This is the same turbo we have used in the apex race kits and although the power is mind blowing they aren't near as much fun to ride as a high boost 19 t 300 plus hp sled.
LL
