M
mynewuseddoo
I have been reading through the threads and I am currious about the max boost pressure I could run on an M8 running straight 100LL fuel. Its not too much more than premium so what the hell eh. I figure if I want a high performance mod then I should run a higher performance fuel. I ride between 1200 and 6000 feet mainly, I'm out in the Shuswap/Revy area.
Also the more I read the more I am curious about something. Do the race gas turbo kits simply just give you more room to play with? For example, if I wanted to, could I run the race gas kit as a pump gas kit? Or is this going to be hard on the race turbo set up? I am curriuos because if I can just run 100LL and lower boost numbers for the majority of the time and then splurge for the race gas and get silly when I want then this would be the kit for me.
One more thing, does the bigger intercooler on the race gas setups affect lag greatly or not much more than the pump gas set up?
Thanks
Thanks
