Matryx 850 with about 300 miles (second motor) is misbehaving.
It ran great all day. I got a low fuel pressure code, and it was trying to die. So, I stopped, and poached a couple gallons from another rider on a boost. His sled ran great all day so I’m assuming the fuel was good. From then on It was not idling and then kept trying to cut out and die at low rpm’s especially when I was chopping the throttle. If I could pin it for a sec it would clean up and hold high rpm. I was able to get it back to the truck. Went to unload at my shop and won’t start. Won’t even try and turn over. I thawed it out, changed plugs, added a tss bypass, and unplugged the kill switch to try and narrow down. Also added 5 gallons of fuel to make sure it has gas. No codes on the 7s that I see.
Any guesses as to what it could be?
