This is what I hope the mfg's will build. I just started a new one where I cut the frame completely off under the swingarm bolt and behind the bottom motor mount and bridged the gap with the tunnel side plates. The paddle tips almost touch the bump on the cases where the shifter shaft crosses. Still needs testing but getting the weight off the ski is the biggest improvement in our sport. Its worth 20 hp when the ski isn't dragging and slowing you down. The Gnarbike looks like a good direction as long as its a light 2 stroke version. The 4 stroke would be too heavy to pickup. We don't need 150hp or automatic transmissions. I Rode the honda africa thing and its a joke. If you can't clutch and shift that's not the machines problem. Learn it or buy a sled. We don't need the manufactureres to handicap an entire industry to appease the lesser skilled masses and we can't expect to convert the entire sled population to single ski. If they aren't dirt bikers, they just don't do well on snowbikes either Its harsh but its just the way it is. Soccer moms have no buisiness buying a sports car with a 6 speed stick shift, Minivans are purpose built for them. For the kind of riding a 800 twin cvt snowbike would be good at, I would be able to ride a stock skidoo 850 and have just as much fun and enjoy the roads a whole lot more.
I just put an 11" wide cmx track on this beast and its amazing. It can 1/4 throttle in waist deep pow and not even have to open the power valve. Its a gear higher everywhere than a kit style snowbike and uses way less fuel. The front end is actually too light at times and certain snow types you can turn the ski lock to lock and it still goes straight. It requires a lean in and lean forward to hook. Its easy to add more ski pressure by limiter strap and shock pressure but in the early season baseless pow you need a snowcat style setup to not get stuck. There is no gas in the front tank, its all in the back with a pulse pump feeding the carb.
![IMG_20180410_084125702.jpg IMG_20180410_084125702.jpg](https://www.snowest.com/forum/data/attachments/240/240438-18d302f39a3d79f25ab2844a2ea43b30.jpg?hash=GNMC85o9ef)
