Manual boost controller
Hallman makes a nice one. I use the one with a ceramic ball in my supercharged car. The ceramic ball is very light and responds quicker, then stainless steel balls.
get the hallman ceramic ball dosnt rust so it wont ever stick on you plus works great on boost creep & spikes.:beer;:D
So, I've got a Hallman RX pro coming - it comes with 2 springs. Which one should I use? I run about 15 lbs.
Most likely you'll have to run the stiffer one. I use the softer one, dailed up almost full and it works out to 8.75-9 psi.
I pre-set mine by connecting the vacuum port to a cooling system pressure tester. Then just used the hand pump and monitored the gauge on the pressure tester, to see where the relief pressure is set to.
MCX w/ manual controller
