As has been alluded to, this is a sled that was purpose built for deep snow and when in deep snow has absolutely no issues with temps unless there's something else wrong.
Normal operating temp is 125* +/- a degree or two.
I run hard, icy trails a lot and while I don't like seeing my temps over 150* it's not hurting the sled. The potential issue you run into with a hotter running temp is the sled is more susceptible to detonation.
IIRC 194* as indicated on the MFD is when ignition time is interrupted.
I run stock scratchers and find the faster I go the cooler the sled runs when snow is thin. Poking along on a rough trail to the hills or in a bigger group where you can't maintain 15-20 MPH and you WILL overheat in just about all conditions.
