i got a 05 900 rmk and i was going to make a air intake my self any one know how to make one
Rough template and sketch
Transfered to aluminum ready to plasma outView attachment 91366
attached to boost box,can see empty nose with SLP gone
x 3..... but I do understand needing to keep it on a budget.
At that point...use the stock airbox and glue/screw an aluminum shield on the bottom to protect the airbox if you blow a belt (you should ONLY be using the 3211115 belt in this sled, IMO, to help guard against a broken crank)
Open the airbox up and remove the air baffles inside... just make sure that you NEVER drop anything into the airbox once the hood is open!!
Just add some SLP venting to the cowl intake in the hood and some flowrites for good clean FRESH air to the motor
Hi.
How did you fasten the flange to the intake? I'm building something similar and so far the only solution i have come up with is riveting it there more or less for good
MH. WIll it have any effect if you enlarge the stock holes on the inside of the air box on the intake tube? Will any fuel mods need to be made to do this properly?
Here's a picture of the one I made...it draws air mostly from under the hood but is right behind one of the hood vents so it gets some direct cold air. I have so many vents on my sled that I figure the air under the hood is cool enough. It'll be even cooler once I get a mesh hood
