M8 Twisted Turbo Attitude Box modes
I have a 2009 M8 set up with a race gas Twisted Turbo. My question is.....What each mode actually controls? G, Y, R, G/B, Y/B, R/B
Ater researching this, and recieving different answers, it makes me wonder....?
green pilot jet 1.5
yellow neddel jet and accellerator pump 1.5
red main jet fuel off
green blue boost fuel 5
there is no yellow blue on the 8
red blue 7.5 swithch point for the main jet
these settings run about 95 % tunned the onlty setting you need to tune is the boost fuel up or down depending on your boost level and elevation
i got an 08 Race Gas M8....this is what im running now
Fuel pressure at Idle = 40lbs
green - 1.5
yellow - 1.5
red - off (blinking fast on the far right LED)
Green/Blue - 3.5 keeps me close to 12.5 A/F when i adjusting anytwhere between 10 and 16lbs of boost
RED/Blue - 7 feels good at lower boost and 5.5 feels better at higher boost
understand you must lightly either of the 3 buttons or the thing will skip a mode or two...these buttons are sensative and designed for a babys touch;)
I'm running my M8 at 10# boost with these numbers at approximately 7000' - 8000' in elevation.
G = 1.5
Y = 1.5
R = off
G/B = 5.5
R/B = 7.5
Running G/B at 5.0 my A/F is at about 12.5.
Running G/B at 5.5 my A/F ia at about 12.1.
What alltitude are you running those numbers at?
green - 1.5
yellow - 1.5
above you say that off is blinking fast to the far right is this correct or did you mean to the far left, I thought the further right you went the richer it got.
