I thought it's time I just started a thread on this, browsed and commented on a few others and got help, but need more specifics. Here's the story, picked up a 2010 M8 Cutler Stage II turbo. Had a blown DD but was supposed to be Pull & go once that was fixed. I put a good used DD in and so far haven't got a ride out of it that something hasn't went wrong. Anyway now it's running OK at the beginning of the ride, but if I shut it down for 10min or so, then re-start, it'll idle low, like 800RPM then if I even touch the throttle it bogs & dies. It gets worse, until it won't even start, then after pulling 50 times or so, it'll run again, after stalling a few more times, it'll start acting normal again, really weird, TPS sensor maybe? so far I've replaced reeds (they were shot) fixed boost leaks, set up waste gate, cleaned power valves, adjusted fuel press, right now it's good at 38PSI . This thing has some other issues too, but this one is most annoying. Only 1300km on the sled and 450 on turbo kit, according to previous owner.
