L
Lattitude
New member
Alright, My boon dockers pg runs excellent on the top, but runs terrible just after clutch engagement. If you can keep it above 5000 rpms it will rip all day, but coming down a decent or trail it acts like I fouled a plug and it pretty much dies. It never actually dies, but you have to feather the throttle to clean it out. It literally almost throws you over the bars. It gets much worse the warmer the sled gets. I live at 10k and ride up to 12k, I use 6 gallons of 91, 3 of av gas, and 1/2 gallon of toluene per tank. My 3k is 0,0,0. 5k is -3,-5,0 and psi os 10,28,48 dc is 53/88 @ 8 lbs of boost. New top end about 300 miles ago, sled has run perfect except the low end problem the last 100 miles, could it be the reeds? I would greatly appreciate any thought, I have richened and leaned out the bottom end with no real change. Also the max get reading on a long,long pull is 1260. This makes this sled almost worthless for boondocking at the moment. Thanks again for any thought!!
