Ok. Trying to make my sled better. Grab a coffee, I'm going in depth to describe everything in detail.
Was told by lots of people, and lots of forum threads the sweet spot for an M7 is an Orange primary spring, with OEM recommended weights for my altitude I ride. Also a 10.4" secondary, and further to that a torsional conversion.
So I got the orange primary spring. Left the 68g weights in it as I ride 6-9k ft.
Then I picked up a M1000 10.4 secondary with an RK Tek torsional conversion. It has a blue spring that I think is the Speedwerks spring, and a 34 degree helix which RK Tek says is what I want.
Now the issues. Mid throttle.. if I punch it. I get a bog / it breaks up. If I wik the throttle up into RPMs I get to the 7850 - 7900 rpm sweet spot im told the M7 likes.
Now, in deep pow.. rpms spike.. and I get NO track speed... again.. If I wik the throttle and build up track speed.. it works ok.. but then I get going too fast for boondocking.
So I adjusted the secondary tension to the lowest setting, and then a little further by taking the whole cover a bolt back (90 degrees) and going a little tighter on the adjustment hole which was the equivalent of going back another notch or two. It got marginally better, but the issue persisted.
I swapped back to the OEM yellow/white primary spring and the mid throttle bog / sputter is gone.. but in pow I still lose track speed and the RPM spikes.
Lastly I have checked belt deflection. Seems that even with the adjustment backed right off.. and the cogs of the belt sticking up out of the clutch i still have more than the 1" RK Tek suggests in the instructions.
I am at my wits end. When it works.. I can feel how much better this setup can be.. Pulls hard, GOBS more bottom end. But in the steep and deep it's a pain.
Any suggestions would be muchly appreciated
