K
katmanduex
New member
Have an 06 M7 with BD racegace setup, first year and half no problems what soever. First of last year burned it down early on a warmer day, rebuilt it, and again at the end of last year. Felt detonation at full throttle, eased off, tried again, and lucky to get home both times. Once on pto, once on the other side. Looked liked detonation or lack of fuel. checked everything both times. Wiring/ground, went up on settings for upper boost and rpm, checked for air leaks, sent in ecu to Cat and box to BD ( no problems ). Checked secondary injectors (worked in the field and once we were home ) checked fuel preasure both time, kept an eye on EGT's, had stock and aux. fuel pump checked out ( even changed aux pump after 1st time) Anyway I had the box remamped for the ADA program the last time and am a little gunshy to pull the trigger when the snow flies. Any suggestions?
Thanks, KB
PS running 7500 to 13000 ft, strait 112 octane premixed
Thanks, KB
