Both sides going IN to the rectifier have a + charge but after 'rectifying' it comes OUT as a DC+ and a DC- so theoretically if you're pulling DC+ out you would also have to hook your ground back to the DC- coming out of the rectifier just like you have to do with the fuel pump. I should've known this.
Sorry guys, but that is plain wrong.
AC is alternating current That mean one AC lead is + and the other is - for a brief part of a second. The next instant the lead that was + then goes - and the other lead that was - then goes + . The AC in your house does this 60 times per second. In a sled it does it more often.
If both leads were positive then you could have no current flow. Electrons flow from one polarity to the other. It will not flow between two of the same polarities at the exact same time.
When you put a bridge rectifier in an AC circuit you are using 4 diodes connected in a way that allows the polarity to flop back and forth on the input but come out + and - on the output.
I said in an earlier post that you can't hook the - of the bridge rectifier up to chassis ground if the AC is also grounded on one side. Let me clarifiy a bit more:
Well of course you can, but you will effectively short 1/2 of the AC and put a huge load on the stator and eventually burn up the bridge. The other 1/2 of the AC power will still continue to do some work at close to normal voltage. It still looks like you have power.
What is happening: the stator goes from dead short to moderate load to dead short to moderate load 60 - 120 times per second. This would make that particular system act weak and burn up and get a bad rep for having a poor stator..............sound familiar?......M7 stators.....LOL
If you look at Ms with CCUs you will find that the AC is not grounded only the DC...............hmmmmmmm wonder why???
I truely hope this helps understand what is going on with some of these systems.
