You are runnning coolant lines to the turbo, correct? If so, an oil cooler shouldn't be necessary. The only company using an oil cooler is Push and none of the others are having problems with the oil getting too hot. When Push first started building kits they didn't run coolant to the turbo and I think that is why they started using the oil cooler. They now run coolant and use a water cooled oil tank.
